주요 콘텐츠로 건너뛰기
How to easily fix a Xbox 360 drive that wont open.
필요한 것
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 1 단계, 이미지 2개 중 1개 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 1 단계, 이미지 2개 중 2개
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: 2 단계, 이미지 1개 중 1개
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: 3 단계, 이미지 2개 중 1개 How to easily fix a Xbox 360 drive that wont open.: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: 4 단계, 이미지 2개 중 1개 How to easily fix a Xbox 360 drive that wont open.: 4 단계, 이미지 2개 중 2개
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: 5 단계, 이미지 1개 중 1개
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small pulley.
  6. How to easily fix a Xbox 360 drive that wont open.: 6 단계, 이미지 2개 중 1개 How to easily fix a Xbox 360 drive that wont open.: 6 단계, 이미지 2개 중 2개
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
결론
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matt Weatherly
회원 가입일: 09/16/12
1,341 평판
안내서 2개를 작성함
8가이드 댓글
the picture of the exbox is not mine
dongwillows - 답글
the picture you show is not my console
dongwillows - 답글
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - 답글
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - 답글
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 158
전체 시간: 14,003
