주요 콘텐츠로 건너뛰기
How to empty and clean Rival 16131 Toaster crumb tray
필요한 것
  1. How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: 1 단계, 이미지 2개 중 1개 How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: 1 단계, 이미지 2개 중 2개
    • To open the crumb tray, pinch the lever in the photo.
    • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
  2. How to empty and clean Rival 16131 Toaster crumb tray: 2 단계, 이미지 1개 중 1개
    • Now that the tray is exposed, it is possible to clean the face here.
    • Try to not let water get into the toaster as this may damage the heating coil.
    • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
  3. How to empty and clean Rival 16131 Toaster crumb tray: 3 단계, 이미지 3개 중 1개 How to empty and clean Rival 16131 Toaster crumb tray: 3 단계, 이미지 3개 중 2개 How to empty and clean Rival 16131 Toaster crumb tray: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • To remove the tray, the metal hinges must be bent up.
    • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
    • Remove the tray and clean.
결론
작성자
3다른 기여자 명과 함께
Grant Haug
회원 가입일: 09/26/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G8
5 회원들
안내서 6개를 작성함
1가이드 댓글
Thanks! This was helpful. :)
Tracy Emmanuel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 3,525
