필요한 것
To open the crumb tray, pinch the lever in the photo.
If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
이 단계에 사용된 도구:Tweezers$4.99
To remove the tray, the metal hinges must be bent up.
While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
Remove the tray and clean.
거의 끝나갑니다!
결론
