소개
Doubling battery / extending battery /
Connecting 2 batteries and increasing backup
  1. Firstly i have started with purchasing 1 battery of same kind and charging both fully by connecting on tablet Then pasted these two batteries with double sided tape with little zigzag type structure as it will helps to reconnect screws later. And then solered both batteries sockets in parllel connection with jumper wires and further glued them with glue gun,u can also use tape for covering wires Now checking the connection by attaching on tablet socket and power it on....... bingo it started,now check out for if there is increasingly in temperatures on battery by touching them
    • Firstly i have started with purchasing 1 battery of same kind and charging both fully by connecting on tablet
    • Then pasted these two batteries with double sided tape with little zigzag type structure as it will helps to reconnect screws later. And then solered both batteries sockets in parllel connection with jumper wires and further glued them with glue gun,u can also use tape for covering wires
    • Now checking the connection by attaching on tablet socket and power it on....... bingo it started,now check out for if there is increasingly in temperatures on battery by touching them
    • If all the are things set then properly covere the back of tablet with insulating tape
    • Now restart it
    • Enjoy your increased backup. ...i have used it continuesly for 13 hrs and yet 13 % was remaining
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Uploaded steps in pic Uploaded steps in pic
    • Uploaded steps in pic
결론
Ojasvi
회원 가입일: 2017년 11월 26일
101 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 110
