주요 콘텐츠로 건너뛰기
How to extract a leaked battery from a pocket-torchlight
필요한 것
  1. How to extract a  leaked battery from a pocket-torchlight, battery: 1 단계, 이미지 1/2 How to extract a  leaked battery from a pocket-torchlight, battery: 1 단계, 이미지 2/2
    • To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
결론
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
다른 2명이 해당 안내서를 완성하였습니다.
ein Stein
회원 가입일: 12/07/20
204 평판
안내서 1개 작성함
댓글 7개
works like a charm! there is no better way. obviously, the leaked battery is being destroyed in the process.
ein Stein - 답글
works for aluminium € 30 “creed-light”
ein Stein - 답글
getting the battery out is much easier than publishing a guide here. wow they make it complicated!
ein Stein - 답글
don’t forget to scratch off any insulating rust caused by the electrolyte on the battery–contacts of the torchlight.
ein Stein - 답글
fragile plastic torches may not withstand the force required to drill, breaking the torch.
unless you have a strong magnet to pull the battery, it is unfortunate.
ein Stein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 57
전체 시간: 956
