소개
The Apple Carplay system in a car (specifically a 2016 Honda Accord in this case) can sometimes malfunctions and cause a few minor technical difficulties. In order to both address and fix these technical difficulties, it is often quite useful to reset the vehicle’s system and make sure the charging connection is secure.
Apple CarPlay can sometimes stop working for a variety of reasons but the main reasons are often USB-charging port connection and iPhone update related. We hope to address both of this issues with this guide.
Our guide will outline these steps and show you how to get your Apple Carplay system back up and running in absolutely no time!
필요한 것
Disconnect your phone's USB cable from the USB port and the Apple Car Play system.
Navigate through your Honda's dashboard settings and pull up the System Settings. Continue to navigate until you find a setting for "Factory Reset"
Once the Factory Reset prompt appears on your screen, select yes and wait a few minutes for your system to reset and return to default settings.
다른 한 분이 해당 안내서를 완성하였습니다.
