주요 콘텐츠로 건너뛰기
How to fix Bad GPS and Cell Phone Signal for LG G2
필요한 것
동영상 개요
  1. How to fix Bad GPS and Cell Phone Signal for LG G2, How to fix Bad GPS and Cell Phone Signal for LG G2: 1 단계, 이미지 1개 중 1개
    • Tools required.
  2. How to fix Bad GPS and Cell Phone Signal for LG G2: 2 단계, 이미지 1개 중 1개
    • Open the back panel and locate these three connectors.
  3. How to fix Bad GPS and Cell Phone Signal for LG G2: 3 단계, 이미지 1개 중 1개
    • Gently lift up all three connectors.
  4. How to fix Bad GPS and Cell Phone Signal for LG G2: 4 단계, 이미지 1개 중 1개
    • Cut a piece of thin cardboard.
  5. How to fix Bad GPS and Cell Phone Signal for LG G2: 5 단계, 이미지 1개 중 1개
    • Cut the pieces close to the size of the connectors.
  6. How to fix Bad GPS and Cell Phone Signal for LG G2: 6 단계, 이미지 1개 중 1개
    • Place the cardboard pieces under all three connectors.
  7. How to fix Bad GPS and Cell Phone Signal for LG G2: 7 단계, 이미지 1개 중 1개
    • Gently press down the conectors.
  8. How to fix Bad GPS and Cell Phone Signal for LG G2: 8 단계, 이미지 1개 중 1개
    • Close the back panel.
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
bonetti
회원 가입일: 07/09/15
610 평판
안내서 1개를 작성함
7가이드 댓글
THANK YOU THANK YOU! Gps locks in seconds and stays locked instead of locking then unlocking after 2 minutes like before. Big ups!
Garrett Wayne - 답글
Vielen Dank, GPS funktioniert bei mir wieder richtig gut. Einer der 3 Kontakte war gut verklebt. Er musste mit einem Teppichmesser unterschnitten werden, was äusserste Vorsicht erfordert.
Peter - 답글
GPS bug I encountered: being from time to time located 50m northward (upsetting when the mains highways are E-W). Working great for the moment :-)
A. Delille - 답글
This solution saved me! Thanks a lot.
ogrean florin - 답글
Sir... Thank you! I was considering to buy another phone, but i love my LGG3 D855 this worked for me too.
I would hug you if i could, thank you! (Hail from Brazil!)
leandrowsp - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 42
전체 시간: 74,478
