주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Follow this guide to potentially solve Wi-Fi issues for the Huawei P8 Lite.
    • 1. go to developer options and select restore to default settings 2. in developer options ,only switch on "Developer Options " , "Stay awake" and "use legacy DHCP client" 3.Then in" Wi-Fi advanced settings" Network notifications "Off" Keep wi-fi on during sleep "Never" Set network connection method "Automatically connect"
    • this is my phones current setting and has stopped my issue
    • please comment if this has helped you with your problem
  1. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
결론
다른 60명이 해당 안내서를 완성하였습니다.
francois
회원 가입일: 2016년 11월 15일
1,712 평판
안내서 1개 작성함
ca marche pas ya t il une autre solution
sammout.rawia - 답글
Admin tolong gimana wifi huawei p8lite saya kok hilang ngk?
darman ybb - 답글
In Developer Options, where is "restore to default settings" and "use legacy DHCP client" ???
"" Set network connection method "Automatically connect" ": you mean Network Operators or Preffered Network Mode ???
aloalo - 답글
l have problem allso my huawei p8 lite
wifi and bluetoth problem wen l turn on wifi is ok but wifi dont see konekcion also wen l go to wifi setinngs ip addrea unavailable.
can sombody help my to fix
also l tray all to fiz but nothing help.
srpskigamer 43 - 답글
Same problem with me
If you will fixed it
Then
Please told me
Muhammad Wali khan Sumbal -
댓글 쓰기
조회 통계:
24 시간 전: 54
7일 전: 373
30일 전: 1,741
전체 시간: 336,596
