소개
Follow this guide to potentially solve Wi-Fi issues for the Huawei P8 Lite.
1. go to developer options and select restore to default settings 2. in developer options ,only switch on "Developer Options " , "Stay awake" and "use legacy DHCP client" 3.Then in" Wi-Fi advanced settings" Network notifications "Off" Keep wi-fi on during sleep "Never" Set network connection method "Automatically connect"
this is my phones current setting and has stopped my issue
please comment if this has helped you with your problem
다른 61명이 해당 안내서를 완성하였습니다.
댓글 68개
ca marche pas ya t il une autre solution
Admin tolong gimana wifi huawei p8lite saya kok hilang ngk?
darman ybb - 답글
l have problem allso my huawei p8 lite
wifi and bluetoth problem wen l turn on wifi is ok but wifi dont see konekcion also wen l go to wifi setinngs ip addrea unavailable.
can sombody help my to fix
also l tray all to fiz but nothing help.
Same problem with me
If you will fixed it
Then
Please told me
