주요 콘텐츠로 건너뛰기
How to fix Logitech Anywhere MX Phantom Double Click
필요한 것
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: 1 단계, 이미지 1개 중 1개
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: 2 단계, 이미지 1개 중 1개
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: 3 단계, 이미지 1개 중 1개
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: 4 단계, 이미지 1개 중 1개
    • Put a piece of tape over the groove.
결론
다른 63명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stefan Magometschnigg
회원 가입일: 11/26/16
1,957 평판
안내서 2개를 작성함
43가이드 댓글
Worked well for me, lets see how long it'll last.
Wynadorn - 답글
Worked for me too...saved a great little mouse!
jcrhino - 답글
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - 답글
Thank you, it worked!
Jakab Ponoczky - 답글
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 44
지난 30일: 298
전체 시간: 50,537
