주요 콘텐츠로 건너뛰기
How to fix Logitech M171 Mouse Laser
  1. How to fix Logitech M171 Mouse Laser, Remove the plastic cover: 1 단계, 이미지 1개 중 1개
    • Remove the plastic cover at the bottom of the mouse
  2. How to fix Logitech M171 Mouse Laser, Remove the battery and wireless key: 2 단계, 이미지 1개 중 1개
    • Remove the battery and wireless key
  3. How to fix Logitech M171 Mouse Laser, Removing the front cover: 3 단계, 이미지 2개 중 1개 How to fix Logitech M171 Mouse Laser, Removing the front cover: 3 단계, 이미지 2개 중 2개
    • Remove the front cover as show
  4. How to fix Logitech M171 Mouse Laser, Removing the sensor: 4 단계, 이미지 1개 중 1개
    • Pull on the sensor to remove it
  5. How to fix Logitech M171 Mouse Laser, Clean the sensor: 5 단계, 이미지 2개 중 1개 How to fix Logitech M171 Mouse Laser, Clean the sensor: 5 단계, 이미지 2개 중 2개
    • Clean the sensor with an tissue soaked in alcohol
  6. How to fix Logitech M171 Mouse Laser, Reassembly insert sensor: 6 단계, 이미지 2개 중 1개 How to fix Logitech M171 Mouse Laser, Reassembly insert sensor: 6 단계, 이미지 2개 중 2개
    • Insert sensor as shown
  7. How to fix Logitech M171 Mouse Laser: 7 단계, 이미지 2개 중 1개 How to fix Logitech M171 Mouse Laser: 7 단계, 이미지 2개 중 2개
    • Install the front plate put the front plate down on the mouse and push Down until it clips in
    • Install battery and USB key and back cover and you’re done
결론
You’re done Thanks for completing the guide
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Maimlian
회원 가입일: 01/27/22
504 평판
안내서 2개를 작성함
3가이드 댓글
Frying the darker plastic cover open without damaging it is near impossible. I have a problem with my mouse wheel and I don't know how to lubricate it or fix the sensor. Can someone help with that?
Efe Şimşek - 답글
These are bad instructions, the top is released with 3 clips accessible under the battery cover, prising it off from above will break those clips. It can be hard to work out where the clips are and how to release them, but there are 3 one on each side and on under the battery. Aside from that the only other retention is a couple of hooks on the mouse buttons.
Gordon Wrigley - 답글
Agree that prizing the top off like this is going to damage it! Maybe my mouse, being blue on top, and black on bottom made this easier to spot, but it was very easy for me to see the three clips on the bottom. Hopefully anyone who wants to open theirs will see your comment and not use the opening tool like this.
Sid R -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 109
전체 시간: 6,061
