주요 콘텐츠로 건너뛰기
How to fix Nikon D3000 shutter release button error
필요한 것
  1. How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: 1 단계, 이미지 2개 중 1개 How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: 1 단계, 이미지 2개 중 2개
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove three 3 mm x 5.5 mm from the bottom left of the camera bottom.
    • Lift the battery cover and remove two 3 mm x 5.5 mm screws from the bottom left of the camera.
    • Remove the screws from the bottom of the case to access the shutter gear.
  2. How to fix Nikon D3000 shutter release button error: 2 단계, 이미지 2개 중 1개 How to fix Nikon D3000 shutter release button error: 2 단계, 이미지 2개 중 2개
    • The second picture shows the bottom plate removed, but this is not necessary and requires intensive disassembling of the camera.
    • Blow out the red gear wheel to clean the wheel from any possible dust or debris.
    • Lubricate the red wheel to lessen the stiffness of the wheel's motion and rotate with the black plastic prying tool.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh
회원 가입일: 08/26/15
328 평판
안내서 1개를 작성함
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015 회원
USFT-MEIER-F15S14G7
4 회원들
안내서 6개를 작성함
2가이드 댓글
I have a d3200 that “at will” will throw this message, so incredibly random. It will be fine then …. the message. Always at the worst moment. I have checked the mirror path and that doesn’t seem to be catching at all. I think I want to try this fix you outlined, but I have. D3200 not a 3000… is everything the same?
MARY M DUNNIGAN - 답글
Hello there.
I attempt many times to resolve issue on my camera. I tried lubricate red gear wheel, but problem persisting.
Does any other thing I need to do?
Salvador Diaz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 40
전체 시간: 12,358
