이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Backup PS5 if possible
Gracefully shutdown the PS5
Unplug all cables and move to a clean working area.
Gather required tools
TR8 Torx(security bit)
P1 Screw Driver
Magnetic Project Mat
Plastic prying tools and Spudger.
Remove Optical side cover
If the optical drive is closest to you, lift up on top left corner.
Clean accessible areas with a non-static brush, compressed-air, or vacuum.
When finished, flip over to remove PS logo side panel.
Remove cover by gently pulling up on corner by PS logo a sliding towards the Vertical Botton of PS5.
Clean area as much as possible
Now flip the ps5 back over to the optical bay side.
Using a spludger tool:
Carefully pry inlet grill from top-left to bottom right.
Using two spludgers
Pry either side of the fan molex connector to disconnect.
TR8 Bit: Remove 4 x screws
2x Screw w/ machine threads top-right and bottom-right (23.3mm)
1x Short screw with coarse threads on bottom left (11.4mm)
1x Long screw w/ coarse threads on top-left (31mm)
Remove fan cover
Remove fan assembly
If heavy accumulation of dust is present on heatsink, proceed with further disassembly.
Use P1 bit driver to remove 1 x Screw
Remove m.2 cover plate and set aside.
Proceeding further will void your manufacturer warranty. Proceed at your own risk!
Remove stick to reveal TR8 bit head screw
TR8 Bit: Remove 11 x screws
These screws vary in sizes so pay attention to where they go.
Remove cover.
Use spudger to depress metal clip for ribbon cable connecting from the main unit to the optical drive.
The optical drive can now be removed and set aside.
Disconnect Ribbon Cable
Flip over
Remove 2 x Torx Screws (29.4mm)
Remove Cover
다른 24명이 해당 안내서를 완성하였습니다.
댓글 9개
Thanks! Man that was alot of screws!
RadioShack - 답글
Awesome video, and one that showed you how to put it back together!! much appreciated sir
This was my second time tearing down the PS5 to clean it... and it was still a very annoying process.
It was made much easier with this guide, though. Thanks for all the work you put in to making it! Much appreciated.
Thanks for tutorial. You just saved me some money
