주요 콘텐츠로 건너뛰기
How to fix TC Electronic Level Pilot static noise
필요한 것
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: 1 단계, 이미지 1개 중 1개
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: 2 단계, 이미지 1개 중 1개
    • Spray the small opening with electrical contact cleaner.
    • Only use electrical cleaning spray.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alpha Dimension
회원 가입일: 09/09/14
409 평판
안내서 1개를 작성함
6가이드 댓글
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - 답글
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - 답글
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - 답글
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - 답글
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 6,182
