주요 콘텐츠로 건너뛰기
How to fix a Bathroom Door that Will Not Latch
필요한 것
  1. How to fix a Bathroom Door that Will Not Latch, How to fix a Bathroom Door that Will Not Latch: 1 단계, 이미지 1/1
    • Check for any screws that may have become loose over time in your door hinges.
  2. How to fix a Bathroom Door that Will Not Latch: 2 단계, 이미지 1/1
    • If you found any loose screws on the door hinge, use your screwdriver to tighten them.
    • To make this easier, you can slightly lift your door while screwing the screws.
  3. How to fix a Bathroom Door that Will Not Latch: 3 단계, 이미지 1/1
    • Examine the faceplate, checking for any loose screws like you did with your door hinges.
  4. How to fix a Bathroom Door that Will Not Latch: 4 단계, 이미지 1/1
    • Use your screwdriver to tighten any loose screws found on the face plate.
  5. How to fix a Bathroom Door that Will Not Latch: 5 단계, 이미지 1/1
    • This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
    • In the photo provided you can tell my plate has been shifted downwards.
  6. How to fix a Bathroom Door that Will Not Latch: 6 단계, 이미지 1/2 How to fix a Bathroom Door that Will Not Latch: 6 단계, 이미지 2/2
    • Use an electric power drill to remove the screws from your strike plate.
  7. How to fix a Bathroom Door that Will Not Latch: 7 단계, 이미지 1/2 How to fix a Bathroom Door that Will Not Latch: 7 단계, 이미지 2/2
    • Make a line on the wall where you will be moving your strike plate. Use something that you will be able to remove, such as a pencil.
  8. How to fix a Bathroom Door that Will Not Latch: 8 단계, 이미지 1/2 How to fix a Bathroom Door that Will Not Latch: 8 단계, 이미지 2/2
    • Using the wood chisel, chisel out the wood above the line to make space for the new placement of the strike plate.
    • An easy way to do this is to tap the end of the chisel with a hammer.
  9. How to fix a Bathroom Door that Will Not Latch: 9 단계, 이미지 1/2 How to fix a Bathroom Door that Will Not Latch: 9 단계, 이미지 2/2
    • Take as many toothpicks you will need to fill up the holes that were created for the previous screw holes, and dip them into the Elmer's glue.
  10. How to fix a Bathroom Door that Will Not Latch: 10 단계, 이미지 1/3 How to fix a Bathroom Door that Will Not Latch: 10 단계, 이미지 2/3 How to fix a Bathroom Door that Will Not Latch: 10 단계, 이미지 3/3
    • Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
    • Let the toothpicks sit for about 10 minutes
  11. How to fix a Bathroom Door that Will Not Latch: 11 단계, 이미지 1/1
    • Place the strike plate in its new position.
  12. How to fix a Bathroom Door that Will Not Latch: 12 단계, 이미지 1/1
    • Using an electric drill, screw your strike plate into the wall.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Shanice Joseph
회원 가입일: 01/21/18
367 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 51
전체 시간: 4,114
