주요 콘텐츠로 건너뛰기
How to fix a Chipped Snowboard Edge
필요한 것
  1. How to fix a Chipped Snowboard Edge, How to fix a Chipped Snowboard Edge: 1 단계, 이미지 2개 중 1개 How to fix a Chipped Snowboard Edge, How to fix a Chipped Snowboard Edge: 1 단계, 이미지 2개 중 2개
    • Apply the snowboard onto a clean and stable surface, making sure it won't move a lot.
    • Clean the board of any dust and dirt.
  2. How to fix a Chipped Snowboard Edge: 2 단계, 이미지 3개 중 1개 How to fix a Chipped Snowboard Edge: 2 단계, 이미지 3개 중 2개 How to fix a Chipped Snowboard Edge: 2 단계, 이미지 3개 중 3개
    • Apply painter's tape around the damaged edge, leaving the damaged edge exposed.
    • This will protect the board while sanding the damaged edge.
    • Always use painter's tape. Regular tape can be damaging to the boards outer coat.
  3. How to fix a Chipped Snowboard Edge: 3 단계, 이미지 2개 중 1개 How to fix a Chipped Snowboard Edge: 3 단계, 이미지 2개 중 2개
    • Sand out the chipped area so that the indent is smooth.
    • There should be no more rough edges where the chipped area is.
    • After your done sanding, make sure to clean away any leftover dust with warm water and a clean cloth.
  4. How to fix a Chipped Snowboard Edge: 4 단계, 이미지 2개 중 1개 How to fix a Chipped Snowboard Edge: 4 단계, 이미지 2개 중 2개
    • Squeeze out a little epoxy into the chipped area.
    • Use a toothpick to guide the epoxy into the crevasses.
    • The epoxy can be very hard to work with, be slow with it.
  5. How to fix a Chipped Snowboard Edge: 5 단계, 이미지 1개 중 1개
    • Clamp the chipped area to make sure it stays tight and compressed.
    • Let it stay clamped for 1-2 hours to allow the epoxy to harden.
  6. How to fix a Chipped Snowboard Edge: 6 단계, 이미지 3개 중 1개 How to fix a Chipped Snowboard Edge: 6 단계, 이미지 3개 중 2개 How to fix a Chipped Snowboard Edge: 6 단계, 이미지 3개 중 3개
    • After the epoxy is hard, sand the excess epoxy until it's flush with the board.
    • Carefully and slowly remove the tape.
    • Allow the epoxy to cure for at least 24 hours before use.
    • A full cure is typically achieved between 24 hours and 7 days. Refer to your epoxy container for cure times.
결론
Your snowboard should be good as new, test out your board after it the epoxy fully hardens.
작성자
1다른 기여자 명과 함께
Zeeshan Tanveer
회원 가입일: 01/31/23
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 83
전체 시간: 3,882
