주요 콘텐츠로 건너뛰기
How to fix a Detached Backpack Strap
필요한 것
  1. How to fix a Detached Backpack Strap, Prepare the area for the repair: 1 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Prepare the area for the repair: 1 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Prepare the area for the repair: 1 단계, 이미지 3개 중 3개
    • Locate the detached strap and gather all the tools needed for the fix.
    • Note: In this example, the strap is not fully detached. However, if the backpack is worn extensively, the seam could break and the strap could come off completely.
  2. How to fix a Detached Backpack Strap, Clean the area: 2 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Clean the area: 2 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Clean the area: 2 단계, 이미지 3개 중 3개
    • Remove the strap from the seam.
    • Use a pair of scissors and a seam ripper to cut the strap off and remove any loose threads.
    • Tip: You may need to remove both internal and external stitches. In this example, an internal binding (yellow arrow) also needed to be cut.
  3. How to fix a Detached Backpack Strap, Remove the strap: 3 단계, 이미지 2개 중 1개 How to fix a Detached Backpack Strap, Remove the strap: 3 단계, 이미지 2개 중 2개
    • Once the area has been cleaned, completely remove the strap from the seam in preparation for the next step.
  4. How to fix a Detached Backpack Strap, Fix the strap in place: 4 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Fix the strap in place: 4 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Fix the strap in place: 4 단계, 이미지 3개 중 3개
    • Reintroduce the strap into the seam and secure it in place with sewing pins.
  5. How to fix a Detached Backpack Strap, Start sewing: 5 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Start sewing: 5 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Start sewing: 5 단계, 이미지 3개 중 3개
    • Use a sewing machine to stitch the strap in place.
    • Make sure the needle is positioned on the side and not in the middle (red arrow).
    • After stitching, make sure that the seam is done back and forth and that it is fully fixed.
  6. How to fix a Detached Backpack Strap, Reinforce the stitch: 6 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Reinforce the stitch: 6 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Reinforce the stitch: 6 단계, 이미지 3개 중 3개
    • Although a sewing machine is preferred, if the fabric is too thick, the stitching can be reinforced by hand.
    • Note: In this example, we use a combination of hand stitching and a sewing machine.
  7. How to fix a Detached Backpack Strap, Clean the area: 7 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Clean the area: 7 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Clean the area: 7 단계, 이미지 3개 중 3개
    • Use a pair of scissors to clean the area and remove any loose threads.
  8. How to fix a Detached Backpack Strap, Finished and ready!: 8 단계, 이미지 3개 중 1개 How to fix a Detached Backpack Strap, Finished and ready!: 8 단계, 이미지 3개 중 2개 How to fix a Detached Backpack Strap, Finished and ready!: 8 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 20
전체 시간: 142
