주요 콘텐츠로 건너뛰기
How to fix a blown heater element in a Toaster
필요한 것
동영상 개요
    • Insert wisdom here.
    • how to fix a toaster
결론
Not too difficult, you need patience though.
다른 4명이 해당 안내서를 완성하였습니다.
jon
회원 가입일: 05/15/16
2,949 평판
안내서 22개 작성하였습니다
댓글 2개
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - 답글
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 40
30일 전: 164
전체 시간: 25,037
