주요 콘텐츠로 건너뛰기
How to fix a break in a Belkin Lightning Charger Cable
필요한 것
  1. How to fix a break in a Belkin Lightning Charger Cable, How to fix a break in a Belkin Lightning Charger Cable: 1 단계, 이미지 1개 중 1개
    • Unplug the charger before starting with the repair.
    • Locate the damaged area on the charger.
  2. How to fix a break in a Belkin Lightning Charger Cable, Cut out the broken section: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flush Cutter
    $29.99
    • Cut out the part where the wire is broken using a pair of wire cutters.
  3. How to fix a break in a Belkin Lightning Charger Cable, Strip the cable: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flush Cutter
    $29.99
    • Strip off about 3cm of the black insulation with the wire strippers to expose the red and black wire on both parts of the cable.
    • You can use your flush cutters or a knife as an improvised wire stripper by cutting just enough so that you don't damage the small wires inside and pulling the insulation off.
    • Be safe when using the flush cutters or a knife: Pull away from your face and body when stripping wires.
  4. How to fix a break in a Belkin Lightning Charger Cable, Add Heat-shrink tubing: 4 단계, 이미지 1개 중 1개
    • Slide about 1.75 of Heat-shrink tubing on a black and red wire each.
    • Slide about 5cm of Heat-shrink tubing on a charger cable.
  5. How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: 5 단계, 이미지 2개 중 1개 How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flush Cutter
    $29.99
    • Strip off about 1cm of the insulation of each of the wires with the wire strippers.
    • You can use your flush cutters as an improvised wire stripper by cutting just enough so that you don't damage the copper strands inside and pulling the insulation off.
    • Wires are fragile, so when stripping be sure not to snip the wires.
  6. How to fix a break in a Belkin Lightning Charger Cable, Twist the wires together: 6 단계, 이미지 1개 중 1개
    • Twist together the corresponding wires.
    • Be sure all wiring is bonded together.
    • Move the small heat shrinking tubes up to cover the exposed parts of the wires.
  7. 이 단계에 사용된 도구:
    Heat Gun
    $29.99
    • Evenly heat the tubing with a heat gun. Make sure the tube is properly shrinking.
    • The tubing gets hot—hold the cord at the end of each side.
  8. How to fix a break in a Belkin Lightning Charger Cable, Move the Heat-shrink tubing up: 9 단계, 이미지 1개 중 1개
    • Move the large heat shrinking tube up to cover the wires.
  9. How to fix a break in a Belkin Lightning Charger Cable, Heat the Heat-shrink tubing: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Heat Gun
    $29.99
결론
Happy fixing!
작성자
3다른 기여자 명과 함께
Marcus Watson
회원 가입일: 04/11/19
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 1,714
