주요 콘텐츠로 건너뛰기
How to fix a clogged garbage disposal
필요한 것
  1. How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: 1 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: 1 단계, 이미지 2개 중 2개
    • Press the red reset button either on the front or on the bottom of your garbage disposal.
  2. How to fix a clogged garbage disposal: 2 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal: 2 단계, 이미지 2개 중 2개
    • Go to your breaker box and look for the breaker for your dishwasher. It may be attached to another appliance. Switch it off.
    • Do not continue without disconnecting the power.
  3. How to fix a clogged garbage disposal: 3 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal: 3 단계, 이미지 2개 중 2개
    • Unplug the garbage disposal from the outlet underneath the sink.
  4. How to fix a clogged garbage disposal: 4 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal: 4 단계, 이미지 2개 중 2개
    • Disconnect the garbage disposal pipe from the sewer pipe.
    • There may be excess water in this part of the pipe so place the bucket underneath.
  5. How to fix a clogged garbage disposal: 5 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal: 5 단계, 이미지 2개 중 2개
    • Using two screwdrivers, place them in the hooks on the top of the garbage disposal and push against them clockwise.
  6. How to fix a clogged garbage disposal: 6 단계, 이미지 2개 중 1개 How to fix a clogged garbage disposal: 6 단계, 이미지 2개 중 2개
    • Carefully bring down the garbage disposal from where it was connected to the sink.
  7. How to fix a clogged garbage disposal: 7 단계, 이미지 1개 중 1개
    • Remove the splashguard at the top of the garbage disposal that you normally see from the top of your sink.
  8. How to fix a clogged garbage disposal: 8 단계, 이미지 1개 중 1개
    • Using a screwdriver dislodge and remove any items clogging the disposal. This will give you an opportunity to manually move the blades around.
    • Never use your hand to move the blades.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katie Daffer
회원 가입일: 02/23/16
269 평판
안내서 1개를 작성함
Texas Tech, Team 26-1, Rauch Spring 2016 Texas Tech, Team 26-1, Rauch Spring 2016 회원
TTU-RAUCH-S16S26G1
3 회원들
안내서 1개 작성
2가이드 댓글
Would suggest also if you have a garbage disposal that has the hex wrench insert on the bottom you can use that to also spin the impeller to unjam the unit. Otherwise good to go
turbid - 답글
Yes most disposal units come with an Alan key so you can rotate the blades from the bottom of the unit. Rotate in each direction to un jam any thing check the red reset button. Then try it again most jams occur when not enough water is used to flush away the grinds.
Keith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 62
전체 시간: 4,685
