주요 콘텐츠로 건너뛰기
How to fix a dead FLIR ONE
필요한 것
  1. How to fix a dead FLIR ONE, Open FLIR ONE: 1 단계, 이미지 1/2 How to fix a dead FLIR ONE, Open FLIR ONE: 1 단계, 이미지 2/2
    • Open the device with the opening tool in crack along top edge of back side.
    • Continue carefully opening the device around all four edges.
  2. How to fix a dead FLIR ONE, Separate the two halves: 2 단계, 이미지 1/1
    • The two halves will separate very easily and the battery connector will detach very easily.
  3. How to fix a dead FLIR ONE, OPTIONAL - Check battery: 3 단계, 이미지 1/1
    • OPTIONAL
    • Lay two pieces of 30 gauge solid insulated wire (wire-wrap wire) onto connector. Press into the two slots to make connections.
    • CAUTION - any wire or probe larger than 30 gauge is likely to damage the connector.
    • Use a multimeter to check the battery voltage, it should be about 3.7 V.
  4. How to fix a dead FLIR ONE, Reconnect battery: 4 단계, 이미지 1/1
    • Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
  5. How to fix a dead FLIR ONE, Reassemble: 5 단계, 이미지 1/1
    • Press the two halves of the case together. You might see the LED in the button light or start blinking!
  6. How to fix a dead FLIR ONE, Done: 6 단계, 이미지 1/1
    • Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • When charged, reconnect device to phone and try it!
    • You may get the message "Camera Files Not Received. Camera files could not be read, temperature accuracy and MSX alignment may be degraded." This is apparently a bug in some versions of the FLIR ONE App.
결승점
다른 20명이 해당 안내서를 완성하였습니다.
Frank Demarest
회원 가입일: 10/17/17
793 평판
안내서 1개 작성함
댓글 25개
Totally worked for mine! I almost gave up on it after seeing the YouTube video of the guy smashing his with a hammer. In addition I used a little bit of stablilant 22 contact enhancer product. Thanks Frank!
Todd - 답글
Cool you shared this info with other folks!
Worked for my Android device!
Dmitry G.L. - 답글
I can easily find a 185mAh battery but not a 350mAh. Not sure if anyone knows why its shrunk?
185 seems to work fine though.
Great guide. Sooooo easy.
georgedavies@hotmail.com - 답글
I’m just wondering the same thing : why is there only 185 mAh batteries, with the same model number, and no 350 mAh available online
matthieuv -
Same. Just going to go with the 185. If the battery life is too short, I've had luck (with the current completely dead battery) with plugging it into a small usb powerbank.
gim -
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 33
30일 전: 188
전체 시간: 39,286
