주요 콘텐츠로 건너뛰기
How to fix a dead IHome iBT76
필요한 것
  1. How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: 1 단계, 이미지 3개 중 1개 How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: 1 단계, 이미지 3개 중 2개 How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: 1 단계, 이미지 3개 중 3개
    • Flip the on/off switch to off.
    • Flip the speaker over on and remove the label.
    • Remove the four phillips head screws.
  2. How to fix a dead IHome iBT76: 2 단계, 이미지 1개 중 1개
    • Remove the bottom plate.
    • Unplug the white plug.
    • Plug it back in.
  3. How to fix a dead IHome iBT76: 3 단계, 이미지 1개 중 1개
    • Enjoy your speaker again.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Salemboot
회원 가입일: 02/24/19
348 평판
안내서 1개를 작성함
14가이드 댓글
OMG! Salemboot, you are absolutely incredible! First the lights went out, then it wouldn’t work without being plugged in, the charging light never came on, and it finally stopped working altogether…I was so disappointed. This was a gift with sentimental value so thank you very, very much!
aviteks - 답글
Double OMG !! Thanks for making us Dad’s look cool to our kids. Worked like a charm. I would not have had the courage to tackle this without your post. My little guy loves this speaker and uses it all the time. He was heart broken when it failed. Now he thinks I can fix anything. Many thanks!!
T Stu - 답글
How did you remove the bottom label?
Joel M -
How do I remove the label without breaking it??
Joel M - 답글
EXACTLY! How do you?
Hs Clan -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 77
전체 시간: 4,997
