주요 콘텐츠로 건너뛰기
How to fix a jammed nozzle on a ProtoCentre 999
필요한 것
  1. How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: 1 단계, 이미지 3개 중 1개 How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: 1 단계, 이미지 3개 중 2개 How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: 1 단계, 이미지 3개 중 3개
    • ON the power switch.
    • Go to prepare .
    • Click the option , preheat.
    • Go back to the main menu, check whether the nozzle temperature is increasing to the set temperature.
  2. How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: 2 단계, 이미지 3개 중 1개 How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: 2 단계, 이미지 3개 중 2개 How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: 2 단계, 이미지 3개 중 3개
    • Remove the teflon tube from the nozzle block.
    • In some case the teflon tube will not come out free. In this case, increase the temperature to 280 deg and try to remove the teflon tube.
  3. How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: 3 단계, 이미지 3개 중 1개 How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: 3 단계, 이미지 3개 중 2개 How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: 3 단계, 이미지 3개 중 3개
    • Take the needle, and try to clean it from the top of the nozzle block.
    • In some case, jammed filament will not come out free. At this case , increase the nozzle temperature to 280deg and remove the nozzle cooler fan.
    • And try to clean the nozzle from the top with the help of a needle and a nose plier.
    • If the nozzle is again not clean, try to clean the nozzle by removing the nozzle tip with the help of a nose plier and spanner. Again clean it with the help of a needle.
    • NOTE: Be careful while removing the nozzle tip. If you extract more pressure on the nozzle tip, it may break. So be careful while doing it.
  4. How to fix a jammed nozzle on a ProtoCentre 999, REASSEMBLE.: 4 단계, 이미지 2개 중 1개 How to fix a jammed nozzle on a ProtoCentre 999, REASSEMBLE.: 4 단계, 이미지 2개 중 2개
    • Reassemble the nozzle tip again with the help of the nose plier and spanner after cleaning the nozzle.
    • Reinsert the teflon tube.
  5. How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: 5 단계, 이미지 3개 중 1개 How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: 5 단계, 이미지 3개 중 2개 How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: 5 단계, 이미지 3개 중 3개
    • Go to prepare
    • click on move axis
    • Select the extrude
    • Rotate the knob in clock wise direction and check the extrusion.
  6. How to fix a jammed nozzle on a ProtoCentre 999, GO FOR PRINT: 6 단계, 이미지 1개 중 1개
    • Now you can go for the print .
결론
작성자
5다른 기여자 명과 함께
abhishek j
회원 가입일: 06/27/17
1,193 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 179
