주요 콘텐츠로 건너뛰기
How to Fix a Leaking Garbage Disposal at Flange
필요한 것
  1. How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: 1 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: 1 단계, 이미지 2/2
    • Unplug the garbage disposal from the power source.
    • Be sure to place the wall plug in a dry location for the duration of the fix.
  2. How to Fix a Leaking Garbage Disposal at Flange: 2 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange: 2 단계, 이미지 2/2
    • Loosen and disconnect the dishwasher drain hose from the garbage disposal unit by loosening the clamp and removing the screws with a flathead screwdriver.
    • Pull the gray tube from the disposal.
  3. How to Fix a Leaking Garbage Disposal at Flange: 3 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange: 3 단계, 이미지 2/2
    • Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
    • Disconnect the lock-nut at the flange.
    • Adequate lighting is imperative for this step.
  4. How to Fix a Leaking Garbage Disposal at Flange: 4 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange: 4 단계, 이미지 2/2
    • Use the screwdriver to turn the locking ring counter clock-wise, disengaging the drain hose and disposal.
    • You will be able to hear the locking ring come undone after pushing it forcefully to the left.
    • The disposal will drop down—be sure to catch the disposal and place on the bottom of the sink.
    • Move from underneath the sink to the top of the sink.
  5. How to Fix a Leaking Garbage Disposal at Flange: 5 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange: 5 단계, 이미지 2/2
    • To remove the flange, push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
    • Scrape off ALL excess putty from the flange and the sink.
  6. How to Fix a Leaking Garbage Disposal at Flange: 6 단계, 이미지 1/3 How to Fix a Leaking Garbage Disposal at Flange: 6 단계, 이미지 2/3 How to Fix a Leaking Garbage Disposal at Flange: 6 단계, 이미지 3/3
    • Remove a small ball of putty and roll into a golf ball shape.
    • Roll the putty flat into a snakelike shape, approximately 3/4 inch diameter.
    • Be sure that the putty is long enough to wrap completely around the flange.
  7. How to Fix a Leaking Garbage Disposal at Flange: 7 단계, 이미지 1/2 How to Fix a Leaking Garbage Disposal at Flange: 7 단계, 이미지 2/2
    • Wrap the putty around the flange and place the flange back into the sink.
    • Press down hard into the sink and remove any excess Plumber's Putty.
  8. How to Fix a Leaking Garbage Disposal at Flange: 8 단계, 이미지 1/1
    • Reassemble the flange and garbage disposal by reversing these steps.
    • Put a sink stopper in and fill up the sink approximately halfway.
    • Remove the stopper and check underneath the sink to make sure there are no leaks.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amy Haren
회원 가입일: 01/19/18
175 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S19-G2, Stewart Spring 2018 USF Sarasota-Manatee, Team S19-G2, Stewart Spring 2018 회원
USFSM-STEWART-S18S19G2
1 회원
안내서 1개 작성하였습니다
댓글 한 개
How do you stop the flange screws from backing out? Fixed it yesterday and screws were loose already this evening…help…
Mike T - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 102
전체 시간: 6,197
