주요 콘텐츠로 건너뛰기
How to fix a printer that won't print
필요한 것
    • Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
    • A screwdriver.
    • A computer.
    • Printer ink.
    • This guide (obviously)
    • When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
    • Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
    • Remove the panel n
결론
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lappy4861
회원 가입일: 03/11/24
183 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 47
전체 시간: 486
