주요 콘텐츠로 건너뛰기
How to fix a ripped back pocket of jeans
필요한 것
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 1개 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 2개 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 3개
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: 2 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 2 단계, 이미지 2개 중 2개
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: 3 단계, 이미지 1개 중 1개
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: 4 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 4 단계, 이미지 2개 중 2개
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: 5 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 5 단계, 이미지 2개 중 2개
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: 6 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 6 단계, 이미지 2개 중 2개
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 1개 How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 2개 How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 3개
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: 8 단계, 이미지 1개 중 1개
    • Cut the loose threads to clean up the sewing.
결론
작성자
1다른 기여자 명과 함께
Ashley Dembroski
회원 가입일: 07/19/20
157 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G2, Cardinal Summer 2020 UW Tacoma, Team S1-G2, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G2
1 회원
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 43
전체 시간: 4,459
