주요 콘텐츠로 건너뛰기
How to fix a stuck Sony Cyber-shot DSC-P10 lens cover
필요한 것
  1. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover, How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: 1 단계, 이미지 1/1
    • Pull back the lens shutters manually if necessary.
    • NOTE: A can of compressed air can be found in almost any store
  2. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: 2 단계, 이미지 1/2 How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: 2 단계, 이미지 2/2
    • Blow the area inside the flaps and around them with the can of compressed air.
    • If the flaps don't immediately work, continue to attempt to blow the debris out while periodically checking to see if the problem is fixed
결론
After following this guide, the lens flaps should open and close freely as necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
Renee
회원 가입일: 10/29/11
125 평판
안내서 1개 작성함
UW Stout, Team 1-1, Zhou Fall 2011 UW Stout, Team 1-1, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G1
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 45
전체 시간: 4,842
