주요 콘텐츠로 건너뛰기
How to fix a torn piece of fabric
필요한 것
  1. How to fix a torn piece of fabric, Torn Fabrics: 1 단계, 이미지 1개 중 1개
    • The tools needed are in the following pictures. Make sure the fabric you are using matches the fabric being repaired if its clothing.
  2. How to fix a torn piece of fabric: 2 단계, 이미지 1개 중 1개
    • Press the thread through the hole of the needle. Getting the end of the needle wet will help it through easier. Once that is done make a firm knot to hold it in place.
  3. How to fix a torn piece of fabric: 3 단계, 이미지 1개 중 1개
    • Place the new fabric on top of the torn fabric and poke the needle through the end of the tear. Make sure to make a knot to hold the first incision through.
  4. How to fix a torn piece of fabric: 4 단계, 이미지 1개 중 1개
    • Began looping your thread through the new fabric on top of the torn fabric.
  5. How to fix a torn piece of fabric: 5 단계, 이미지 1개 중 1개
    • Take your time looping the thread through and make sure it is secured.
  6. How to fix a torn piece of fabric: 6 단계, 이미지 1개 중 1개
    • Once at the end of the fabric make a secured knot and cut any extra fabric left.
  7. How to fix a torn piece of fabric: 7 단계, 이미지 1개 중 1개
    • Look at your finished project to make sure it is clean.
결론
작성자
2다른 기여자 명과 함께
Kris McLemore
회원 가입일: 02/04/19
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 970
