주요 콘텐츠로 건너뛰기
How to fix a wobbly Sony Ericsson w600i swivel
필요한 것
  1. How to fix a wobbly Sony Ericsson w600i swivel, Back housing: 1 단계, 이미지 1/1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  2. How to fix a wobbly Sony Ericsson w600i swivel: 2 단계, 이미지 1/1
    • Swivel the phone open.
  3. How to fix a wobbly Sony Ericsson w600i swivel: 3 단계, 이미지 1/1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  4. How to fix a wobbly Sony Ericsson w600i swivel: 4 단계, 이미지 1/1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  5. How to fix a wobbly Sony Ericsson w600i swivel: 5 단계, 이미지 1/1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  6. How to fix a wobbly Sony Ericsson w600i swivel: 6 단계, 이미지 1/2 How to fix a wobbly Sony Ericsson w600i swivel: 6 단계, 이미지 2/2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  7. How to fix a wobbly Sony Ericsson w600i swivel: 7 단계, 이미지 1/3 How to fix a wobbly Sony Ericsson w600i swivel: 7 단계, 이미지 2/3 How to fix a wobbly Sony Ericsson w600i swivel: 7 단계, 이미지 3/3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  8. How to fix a wobbly Sony Ericsson w600i swivel: 8 단계, 이미지 1/1
    • The back housing is now disassembled, and the swivel assembly is revealed.
  9. How to fix a wobbly Sony Ericsson w600i swivel, How to fix a wobbly Sony Ericsson w600i swivel: 9 단계, 이미지 1/1
    • Tighten the four small Phillips screws.
    • The swivel assembly should now be less wobbly and loose, improving the function of the phone.
    • The screws are Phillips, 2.4mm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Beau Blanchard
회원 가입일: 09/30/12
20 평판
안내서 6개 작성하였습니다
University of Maine, Team 1-5, Diaz Fall 2012 University of Maine, Team 1-5, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G5
1 회원
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 587
