소개
Outline what you are going to teach someone how to do.
필요한 것
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Tighten the four small Phillips screws.
The swivel assembly should now be less wobbly and loose, improving the function of the phone.
The screws are Phillips, 2.4mm.
다른 한 분이 해당 안내서를 완성하였습니다.
