주요 콘텐츠로 건너뛰기
How to fix alignment on an E-TKT Label Printer
필요한 것
  1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: 1 단계, 이미지 2개 중 1개 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: 1 단계, 이미지 2개 중 2개
    • Reboot the device.
    • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
    • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
  2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Turn off the device to avoid short circuiting the leads of the hall sensor.
    • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
    • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
    • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
    • Make sure to keep the same distance on the transversal (red) axis.
  3. How to fix alignment on an E-TKT Label Printer, Fine tuning: 3 단계, 이미지 2개 중 1개 How to fix alignment on an E-TKT Label Printer, Fine tuning: 3 단계, 이미지 2개 중 2개
    • Enter the web interface and click on SETUP.
    • Now press the TEST-button to the right side of ALIGN.
    • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
    • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
    • The align value ranges from 1 to 9, with 5 being the default (middle) value.
결론
Happy printing!
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,160 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 246
