소개
A simple guide to fix a jammed drive tray on the 360 S, please follow instructions on how to remove the drive from the 360 S first.
필요한 것
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
TheSupport - 답글
Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
HumidTater - 답글
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
Pull the hard drive straight out of the console.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
You will still have your saves and account if you replace your hard drive in the new xbox
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
These are pretty awkward to remove, but once you understand how they work its easy enough. The goal here is to slot the spudger THROUGH the gap of the silver tabs (visible in previous steps image, circled) and then pry. Put pressure against the wall of the Xbox case and push downwards, once you feel the spudger slot in, then apply force away from the Xbox and pull up a little with your free hand.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
Rotate the spudger upward to release the last clip.
if you make a hole right here like the link`s picture you can boot the lock
As the user above me said, please avoid doing it like shown in the guide. It just didn’t work on my Xbox (unless your goal is to destroy the plastic case). Instead, pick some small needle like object (the spudger was too short for this, I used the SIM bit of my iFixit driver kit) and find the right spot on the big sticker which is on the left in the pictures shown in the guide. That spot is just between the text and the column of logos (Dolby Digital, etc.) (https://team-xecuter.com/slim/slim_secre..., picture not mine). Poke it (don’t be too gentle, you have to apply some force) and you will hear the clip release.
Both the above links are dead, i used this YouTube video which shows you the process of getting the hidden clip
I was able to open it by pushing on the sticker to unclamp the clip while another person helped me pull open the case.
Here is a Video that shows the small hole behind the sticker, ist in german but ist good to see how to open that hidden clip easiely.
Release the clip near the front right corner of the top edge securing the right case to the faceplate.
There are 4 black screw that has to be removed before you can detach the other cover. Please note
Sorry, there 5screws, one in the middle and 4 at the edges
Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
Detach the faceplate from the rest of the device.
There isn’t 2 clips there is 4 clips
Remove the single T10 Torx screw holding in the wireless card.
Pull the Wi-Fi board out of the console.
Remove the large white warranty sticker from the metal frame to expose a screw.
Disconnect the optical drive data cable from the back of the optical drive.
Disconnect the power cable from the back of the optical drive.
Lift the optical drive out of the Xbox.
Is there a specific Optical Drive that Microsoft uses in these or can I upgrade my drive?
whitemare0 - 답글
i took my drive out but when installed my replacement it would not work
WAS thinking of possibly trying to repair my son's Xbox 360S, by replacing the optical drive, but after looking at all the spudger steps to get to the drive and then your comment that the replacement might not actually work... forget about it! I ain't going to all that work for possibly nothing... t'ain't worth it!
Anyone want a perfectly working Xbox 360S with a drive the spins game discs upon ejection? We've already bought a replacement, so this unit is for sale... name your price.
Luposian -
In regards to davidgardner301 comment there is a extra step they. Didn't show on this replacement guide in order for your new disk drive to work you will need to remove the origional board connected to thje origional drive that came with the system and soler that onto the new one its a tricky process however its a step most people over look
Without the origional board the xbox will not accept the replacement drive only because each disk drive is coded to work with tat soecific xbox only so your out of luck if you already. Tossed out your old disk drive
The DVD drives are coded to the Motherboard. If you buy the same exact drive to replace the broken one. You will still need to either 1) transfer the DVD circuit board OR 2) get the Firmware from the old DVD drive using a PC and then transfer it to the New DVD. There are website regarding this procedure if you want to look it up.
The Drive unit itself
For the lite-on phillips drive, you pretty much have to use brute force and a little prayer. Once you remove the rubber piece near the back (sound dampner and it keeps the drive from wiggling), remove the sponge foam strip at the front (allows the drive to close silently) and the 4 screws at the corners.
You then remove the top piece (some videos will actually have you remove the top spin plate, but that is not necessary). Slide the drive components towards the front, after lifting the front to clear the base pins from the other half of the case.
Then carefully remove the drive tray from the side lips holding it in place, starting from the back of the drive and using it's flexibility to free it one tab at a time towards the front.
Once free you'll notice a small guide pin on the right side (from the front view) near the gears, manually rotate the gears (lowering the lens assembly) until the pin lines up on the far right side (there should be a guide track for it on the bottom of the tray).
Slide the tray back into place making sure the guide pin is properly aligned into the guide track.
You can do a partial reassembly to test the fix, but be careful as the power cord "key" is a molded part of the case, so it can be inserted upside down.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 5개
Was able to pop tray up on right side out of guide, then moved gears till the pin lined up with bottom of tray, popped tray back into guide. Worked perfectly.
step 35 is not necessary, just gently flip xbox and detach dvd-drive
Thanks for writing this! This guide was really helpful and my xbox is working perfectly again :) never done anything like this before but instructions were clear and I'm pretty happy with myself to be honest. Could do with relevant pictures on the last two steps but overall a really useful and well written guide.
STUCK DRIVE = Need go no further than Step 4. (Photos available)
After removing the top vent you will be able to see a hole in the mesh towards the front.
Beneath the mesh is the side of the DVD case with another hole lining up with hole in mesh. (May have yellow circle around it).
This will need a long thin probe (Nothing I have in my kit) like a perfectly straightened paper clip.
Push the probe through the hole which disengages the lifter inside the DVD player and allows the draw to open.
No need to go past step 4 unless the DVD needs to be opened to remove stuck objects.
