이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer.
Use a pair of tweezers to pull the home button ribbon cable out of its socket.
De-route the home button ribbon cable through the inner case and remove the home button from the iPhone.
You need really thin blade to carefully peel off the plastic film from the back of the button. Do NOT touch the glue with your finger!
After disassembly, you need some white spirit and cotton buds to clean up greenish oxide on both: button back contacts and steel cap's inside.
Last picture shows cleaned details.
On reassembly, you have to position the steel cap in the center of copper contact ring, placing plastic sticker into its respective cavity on the back of the button.
Press the sticker firmly into its place. Don't worry if it doesnt stick all the way round. its position under the glass keeps the details in place. Again, try to prevent touching the glue while disassembling.
Congrats! Re-assemble your device and enjoy your revived home button!
다른 37명이 해당 안내서를 완성하였습니다.
