주요 콘텐츠로 건너뛰기
How to Fix Jammed Nintendo Switch ZR and ZL buttons
필요한 것
  1. How to Fix Jammed Nintendo Switch ZR and ZL buttons, Unscrew the back cover: 1 단계, 이미지 1/1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  2. How to Fix Jammed Nintendo Switch ZR and ZL buttons: 5 단계, 이미지 1/1
    • Resume gameplay!
결론
After following those 7 steps, your gameplay should return to its original state. If the other Joy-Con also has a jammed ZL or ZR button simply repeat the 7 steps above.
다른 12명이 해당 안내서를 완성하였습니다.
Gabriela Cruz-Pagan
회원 가입일: 02/02/20
435 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 회원
USFSM-STEWART-S20S1G1
23 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 53
7일 전: 394
30일 전: 1,708
전체 시간: 91,277
