주요 콘텐츠로 건너뛰기
How to fix jumpy scroll wheel of a computer mouse
필요한 것
  1. How to fix jumpy scroll wheel of a computer mouse, How to fix jumpy scroll wheel of a computer mouse: 1 단계, 이미지 1개 중 1개
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a screwdriver
  2. How to fix jumpy scroll wheel of a computer mouse: 2 단계, 이미지 1개 중 1개
    • Remove the wire from the board by slowly pulling the connector
  3. How to fix jumpy scroll wheel of a computer mouse: 3 단계, 이미지 1개 중 1개
    • 1)Remove the board out of the case
    • 2)Slowly pull out the scroll wheel out of the encoder wheel well
  4. How to fix jumpy scroll wheel of a computer mouse: 4 단계, 이미지 1개 중 1개
    • Slowly remove the metallic clamps from the plastic body to free the plastic case, holding the rotating mechanism .(If possible remover the metallic case fully from underneath the board, if it is not soldered)
    • Pull back or bend the plastic case a little bit for easy insertion of spring
    • Place a small coil spring on the extreme end of the small metallic plate holding the rotating mechanism against the plastic body
    • Pull the other end of the coil and place it on the other end where the scroll wheel is inserted
    • This will ensure that the small metallic plate and rotating mechanism are not loose thereby not causing a jumpy scroll wheel
  5. How to fix jumpy scroll wheel of a computer mouse: 5 단계, 이미지 1개 중 1개
    • Now put this entire contraption inside the metallic case and close the metallic clamps
    • Inserted the scroll wheel into the wheel well and close up the mouse
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jithu Mohan
회원 가입일: 08/14/22
271 평판
안내서 1개를 작성함
3가이드 댓글
quel est la taille du resort qu'on doit acheter pour la réparation
chosela - 답글
Ottima guida come sempre! Complimenti
Paolo Galimberti - 답글
Excellent et si la souris est hors de cause penser à éteindre et rallumer le PC.
Jean-Marie Villez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 24
지난 7일: 176
지난 30일: 793
전체 시간: 36,722
