주요 콘텐츠로 건너뛰기
How to fix paper jams when printing multiple pages at once
필요한 것
  1. How to fix paper jams when printing multiple pages at once, How to fix paper jams when printing multiple pages at once: 1 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once, How to fix paper jams when printing multiple pages at once: 1 단계, 이미지 2개 중 2개
    • Remove the cover on the right side.
  2. How to fix paper jams when printing multiple pages at once: 2 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 2 단계, 이미지 2개 중 2개
    • Open the top lid and remove the toner cartridge.
  3. How to fix paper jams when printing multiple pages at once: 3 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 3 단계, 이미지 2개 중 2개
    • Depress the button which was below the lid you opened in the previous step. At the same time, pull the right plastic side panel of the printer forwards to remove it from the printer. The panel can be quite stubborn, but be patient so you don't break any of the plastic hooks.
  4. How to fix paper jams when printing multiple pages at once: 4 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 4 단계, 이미지 2개 중 2개
    • Open the flap on the rear of the printer.
    • Remove the two screws. Keep track of where the screws came from since different kinds of screws are used throughout the printer.
    • Just a quick reminder that you should remove the power cable if you haven't done so already.
    • Remove the rear panel. To do so, pull on the left side (when viewing from the rear) where there are plastic clips. Also pull from under the flap you opened at the beginning of this step.
    • The panel is kind of hooked at the top of the device, so after pulling it away from the bottom you should be able to remove it by pulling it down. For that it is helpful to move the rear of the printer over the edge of the table.
  5. How to fix paper jams when printing multiple pages at once: 5 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 5 단계, 이미지 2개 중 2개
    • Remove these four screws.
  6. How to fix paper jams when printing multiple pages at once: 6 단계, 이미지 3개 중 1개 How to fix paper jams when printing multiple pages at once: 6 단계, 이미지 3개 중 2개 How to fix paper jams when printing multiple pages at once: 6 단계, 이미지 3개 중 3개
    • Next up you need to disconnect some kind of hook from the top lid.
    • To do so, compress this pin and pull it out to the right.
    • Push the hook down into the printer.
    • When reassembling the printer later, you have to pull this hook out of the printer again. To do so, some kind of hook tool can come in handy. Alternatively, a screwdriver can also be used.
  7. How to fix paper jams when printing multiple pages at once: 7 단계, 이미지 3개 중 1개 How to fix paper jams when printing multiple pages at once: 7 단계, 이미지 3개 중 2개 How to fix paper jams when printing multiple pages at once: 7 단계, 이미지 3개 중 3개
    • Now you can remove the whole top panel of the printer.
    • Open the front paper feed.
    • Push this plastic hook aside.
    • Now remove the top panel. I found it easiest to first twist it clockwise and then lift it up.
    • When reassembling the printer, I found it easiest to just put it straight in instead of rotating it into place.
  8. How to fix paper jams when printing multiple pages at once: 8 단계, 이미지 1개 중 1개
    • This is the printer without the top panel.
  9. How to fix paper jams when printing multiple pages at once: 9 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 9 단계, 이미지 2개 중 2개
    • Next, you can remove the PCB from the right side of the printer.
    • Remove these five screws.
    • Unplug these two cables.
    • Now you can remove the PCB.
  10. How to fix paper jams when printing multiple pages at once: 10 단계, 이미지 3개 중 1개 How to fix paper jams when printing multiple pages at once: 10 단계, 이미지 3개 중 2개 How to fix paper jams when printing multiple pages at once: 10 단계, 이미지 3개 중 3개
    • Remove these two cables.
  11. How to fix paper jams when printing multiple pages at once: 11 단계, 이미지 3개 중 1개 How to fix paper jams when printing multiple pages at once: 11 단계, 이미지 3개 중 2개 How to fix paper jams when printing multiple pages at once: 11 단계, 이미지 3개 중 3개
    • Now you can remove the gear unit from the right side of the printer.
    • Also remove these two screws. Note that they are different from the other screws in this step. Also note that one of them is there to secure a grounding wire which you have to reconnect when reassembling the device.
    • Then you can remove the whole gear unit. Don't worry, all the gears are secured on their axes so they don't fall off.
    • To remove the gear unit, pull the top of the unit forward and then lift the whole thing up because at the bottom center, there is a gap in which one of the gears sits.
    • When reassembling the device, make sure that that one gear is in the gap at the bottom center before pushing the rest of the unit onto the device.
  12. How to fix paper jams when printing multiple pages at once: 12 단계, 이미지 1개 중 1개
    • Now you can see the culprits of the issue: There are two relays, one for each paper feed.
    • When I opened my printer, both of the gears which these relays block were "under tension". Since we want to remove the relays, you should first push on the hooks of the relays so that the gears can turn freely.
    • When reassembling the device, I would recommend to turn the gears until the hook snaps into place again (not sure if that is necessary).
    • When pressing the hook of the relay to the relay itself (even when pressing it with a lot of force) it should not stick and instead retract immediately. So if you find that the hook does stick to the relay, you've probably found your problem. You can see an extreme case of that in this video (not mine).
  13. How to fix paper jams when printing multiple pages at once: 13 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 13 단계, 이미지 2개 중 2개
    • I will only show steps for fixing the bottom relay as fixing the top relay works in exactly the same way.
    • Remove the screw and carefully twist out the relay.
  14. How to fix paper jams when printing multiple pages at once: 14 단계, 이미지 2개 중 1개 How to fix paper jams when printing multiple pages at once: 14 단계, 이미지 2개 중 2개
    • Remove the spring from the relay. Be careful so you don't lose it.
    • Now you can separate the hook from the relay. You can see the sticky material that was used as a dampener.
  15. How to fix paper jams when printing multiple pages at once: 15 단계, 이미지 1개 중 1개
    • Put some kind of tape over the sticky part on both the relay and the hook.
    • I would also recommend putting tape over the center part of the relay and hook (I found that the hook would still stick to the relay a bit without the tape there).
    • When reassembling the relay, be careful so you don't loose the spring - putting it back is tricky and a very thin hook can come in handy.
결론
Pay attention to the comments I made regarding reassembly.
Definitely don't forget to reattach the grounding wire from step 11.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richard
회원 가입일: 01/22/17
1,187 평판
안내서 2개를 작성함
1가이드 댓글
Très bon tuto, une imprimante que je connais bien, très facile à réparer que j'ai réparé plusieurs fois pour plusieurs personnes et ça tourne toujours même sous Windows, 10 et 11.
alain frenois - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 45
전체 시간: 998
