주요 콘텐츠로 건너뛰기
How to fix scroll-wheel issues with Roccat Kone mice
필요한 것
  1. How to fix scroll-wheel issues with Roccat Kone mice, Disconnect the Mouse/Cover Sensor: 1 단계, 이미지 1개 중 1개
    • Unplug the mouse.
    • Cover the optical sensor with tape.
  2. How to fix scroll-wheel issues with Roccat Kone mice, Loosen the Covers/Remove Screws: 2 단계, 이미지 2개 중 1개 How to fix scroll-wheel issues with Roccat Kone mice, Loosen the Covers/Remove Screws: 2 단계, 이미지 2개 중 2개
    • With a heat gun/hair dryer, warm up the covers. This will loosen up the glue that keeps the glider feet attached to the mouse.
    • Once hot, gently try to lift the gliders and work the edges.
    • To reapply, heat the gliders to make the the glue soft, then firmly hold it in place until it cools and holds its grip.
    • Once the gliders are removed, the screws are easily visible
    • Don't touch or dirty the adhesive side of the gliders, or else they won't stick back.
  3. How to fix scroll-wheel issues with Roccat Kone mice, Separate the plastic shell: 3 단계, 이미지 2개 중 1개 How to fix scroll-wheel issues with Roccat Kone mice, Separate the plastic shell: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Be gentle when performing this step. Most Kone models have wires connecting the halves of the shell that may be damaged if you yank on them.
    • Turn the mouse back over and slowly lift off the top cover.
    • You may proceed without disconnecting the two halves if you wish. Ensure both halves are well supported so that the cable is not strained.
    • Use tweezers to disconnect the wires. If your model uses a ribbon cable, you will need to disengage the locking tab on the connector before pulling the cable out.
  4. How to fix scroll-wheel issues with Roccat Kone mice, Where to place the grease and testing the mouse: 4 단계, 이미지 1개 중 1개
    • Spray electrical contact cleaner directly in the space indicated in the picture for several seconds, moving the scroll wheel back and forth as you spray.
    • Once the cleaner spray has evaporated, you may try connecting the mouse to your computer for testing before reassembly. You may encounter odd behavior if you leave the PCB in the shell disconnected while doing this.
    • If several repetitions of this step are not effective, the rotary encoder may be permanently damaged. Consider replacing it or the entire mouse.
결론
다른 36명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Isip V Nicola
회원 가입일: 06/14/12
569 평판
안내서 1개를 작성함
24가이드 댓글
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Michael Ungers - 답글
Thanks for the suggestion, already corrected. :)
Isip V Nicola - 답글
Worked perfect with hair dryer and WD-40 in 15 minutes!
rinaf - 답글
Excellent concise guide. Thank You!!!
brenogrady - 답글
Thanks so much, it worked perfectly on a Roccat Savu. The side buttons were not working anymore after a mouse drop.
Just be patient with the glides & the hair drier.
John Doe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 87
지난 30일: 438
전체 시간: 79,379
