주요 콘텐츠로 건너뛰기
How to fix sporadic dropouts on a FRITZ!Box
  1. How to fix sporadic dropouts on a FRITZ!Box, Reading the log: 1 단계, 이미지 2개 중 1개 How to fix sporadic dropouts on a FRITZ!Box, Reading the log: 1 단계, 이미지 2개 중 2개
    • Note the date and time of the last Internet outage.
    • Open a web browser and log into the user interface of your FritzBox by entering http://fritz.box.
    • Select "System" from the left menu, then "Events" below that.
    • Scroll all the way down in the events and look at the date and time.
    • If the lowest entry, furthest back in time, coincides with the last Internet outage, there is a good chance that it is the error described here.
  2. How to fix sporadic dropouts on a FRITZ!Box, Self test of the FritzBox: 2 단계, 이미지 2개 중 1개 How to fix sporadic dropouts on a FRITZ!Box, Self test of the FritzBox: 2 단계, 이미지 2개 중 2개
    • Start a self test of the FritzBox to make sure that the error does not lie with the FritzBox.
    • To do this, click on Diagnostics and then Function and start the self-test by clicking on Start.
    • During the self-test, the FritzBox functions continue to work and there is no interruption of the Internet connection.
    • If the self-test found errors, the power supply is not the cause.
  3. How to fix sporadic dropouts on a FRITZ!Box, Determine the type of power supply: 3 단계, 이미지 2개 중 1개 How to fix sporadic dropouts on a FRITZ!Box, Determine the type of power supply: 3 단계, 이미지 2개 중 2개
    • Look at the power supply of your FritzBox. If it is the power supply shown here, there is a good chance that it is the described problem.
    • On the nameplate it says: FW7577/EU/12/D
  4. How to fix sporadic dropouts on a FRITZ!Box, Select new power supply: 4 단계, 이미지 1개 중 1개
    • If the previous points apply, a replacement of the power supply will probably help.
    • By the way: I had also opened the power supply, cleaned contact points, re-soldered solder joints and checked electrolytic capacitors by capacitance measurement. Unfortunately, I could not eliminate the error in the power supply. With sporadically occurring errors it is also not so easy.
    • The new power supply does not have to be an original FritzBox power supply. Important is the following:
    • Voltage 12V direct current (DC); current at least 1.4A; the hollow plug, which is plugged into the FritzBox, must have the following dimensions: Diameter 5.5mm outside, 2.5mm inside (pin). The positive pole must be inside (on the pin).
    • A higher-quality power supply is recommended because it has a longer life expectancy or higher reliability and consumes less power via better efficiency.
  5. How to fix sporadic dropouts on a FRITZ!Box, Replacing the power supply: 5 단계, 이미지 1개 중 1개
    • Unplug the old power supply from the power outlet.
    • Trace the cable coming from the old power supply to the FritzBox.
    • Unplug the old power supply from the FritzBox and replace it with the new power supply.
    • Connect the new power supply to the power outlet.
    • If someone has managed to repair the old power supply: Please post instructions here, so that others can benefit from it :-)
결론
Properly dispose of the old power supply as E-Waste.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Ralf Müller
회원 가입일: 10/10/22
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 112
전체 시간: 4,886
