주요 콘텐츠로 건너뛰기
How to fix squeaking on the GEN 2 Wheelchair
필요한 것
  1. How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 1 단계, 이미지 1/3 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 1 단계, 이미지 2/3 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 1 단계, 이미지 3/3
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaking part in order to thoroughly clean it.
  2. How to fix squeaking on the GEN 2 Wheelchair: 2 단계, 이미지 1/1
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  3. How to fix squeaking on the GEN 2 Wheelchair: 3 단계, 이미지 1/1
    • Check to see if the squeaking has stopped by rolling the wheelchair around.
    • If the squeaking continues, recheck the chair thoroughly to locate the problem. Once located, repeat the steps until squeaking has stopped.
결론
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
다른 한 분이 해당 안내서를 완성하였습니다.
Kali Slaughter
회원 가입일: 04/19/13
207 평판
안내서 5개 작성하였습니다
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 회원
CPSU-MANESS-S13S14G8
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 19
전체 시간: 3,373
