주요 콘텐츠로 건너뛰기
How to fix the Acer Chromebook 11 C733 Wi-Fi Issue
필요한 것
추천 문서
    • Make sure your device is powered off
    • Not doing so can result in damage to your device or can result in injury.
  1. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: 2 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: 2 단계, 이미지 2개 중 2개
    • Close your Chromebook and flip the device over so that the bottom of the case is facing up.
    • Remove all 12 case screws from the bottom of the case.
    • Don't worry about making sure these screws are returned to the same spot because they're all the same size.
  2. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 2개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The battery is only held in place with a piece of ESD Tape. Using a set of tweezers, carefully peel away the tape from one end.
    • Once the tape is removed, carefully unplug the battery from the logic board.
  3. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: 4 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: 4 단계, 이미지 2개 중 2개
    • Remove the M.2 Screw, and unplug the Wi-Fi Card from the Logic Board.
  4. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Removing and replacing the Spacer: 5 단계, 이미지 1개 중 1개
    • Using a set of tweezers, carefully remove the rubber spacer from the logic board.
  5. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: 6 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: 6 단계, 이미지 2개 중 2개
    • Once the spacer is removed, place the new spacer in the same area as shown.
결론
To reassemble your device, reconnect the battery and snap the bottom panel back on, and reinsert the case screws.
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
44,583 평판
안내서 51개를 작성함
iFanatics iFanatics 회원
Community
63 회원들
안내서 219개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 71
전체 시간: 1,550
