주요 콘텐츠로 건너뛰기
How to fix the Oven Knob
필요한 것
  1. How to fix the Oven Knob, Oven Knob: 1 단계, 이미지 1개 중 1개
    • Remove the plug of the oven from the socket for safety reasons.
  2. How to fix the Oven Knob: 2 단계, 이미지 2개 중 1개 How to fix the Oven Knob: 2 단계, 이미지 2개 중 2개
    • If the knob is loose, the first step is to completely remove the oven knob.
    • To remove it completely, hold it firmly and pull it straight off the shaft.
    • Make sure the knob is in the off position.
  3. How to fix the Oven Knob: 3 단계, 이미지 3개 중 1개 How to fix the Oven Knob: 3 단계, 이미지 3개 중 2개 How to fix the Oven Knob: 3 단계, 이미지 3개 중 3개
    • If the screw is loosened beforehand, we first need to completely remove the screw from the shaft.
    • To remove the screw, use a Phillips #00 screwdriver to unscrew it from the shaft hole.
  4. How to fix the Oven Knob: 4 단계, 이미지 1개 중 1개
    • Pull the shaft out and hold the shaft firmly. You will see two holes above and below this shaft.
  5. How to fix the Oven Knob: 5 단계, 이미지 1개 중 1개
    • Now insert the screw in one of the holes.
  6. How to fix the Oven Knob: 6 단계, 이미지 3개 중 1개 How to fix the Oven Knob: 6 단계, 이미지 3개 중 2개 How to fix the Oven Knob: 6 단계, 이미지 3개 중 3개
    • Tighten the screw with a screwdriver and make sure the screw is tightly attached.
    • Repeat the same process for the other hole.
  7. How to fix the Oven Knob: 7 단계, 이미지 3개 중 1개 How to fix the Oven Knob: 7 단계, 이미지 3개 중 2개 How to fix the Oven Knob: 7 단계, 이미지 3개 중 3개
    • To fix the knob, slide the knob onto the shaft, aligning it with the D-shaped side of the shaft.
    • The front of the shaft is referred to as D-shaped because its shape resembles the letter D.
    • Now, with a little pressure, push on the shaft and affix the knob onto the shaft.
  8. How to fix the Oven Knob: 8 단계, 이미지 1개 중 1개
    • Test the button by turning on the gas supply, and ensure that the knob operates smoothly and ignites the burner.
결론
This device is reassembled, follow these instructions in reverse order to disassemble.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lovepreet Kaur
회원 가입일: 09/04/23
211 평판
안내서 1개를 작성함
1가이드 댓글
I’ve fixed this on mine several times now, but now the screw won’t tighten on one of them? Almost like whatever it gets screwed into isn’t there? Any idea on what is, not sure it’s worth opening up the back to see if something fell off.
AMKSNAPS - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 52
전체 시간: 910
