소개
This guide actually covers the Petcube Bites 2 Lite, but I'm assuming all their cameras are similar internally.
Mine had stop giving treats because the mine motor had stopped spinning. Since my device was out of warranty, Petcube support didn't have other options than purchasing another device.
I didn't have anything to lose at this point to try to repair it myself, which ended up being not really hard, and is shown in this guide.
필요한 것
동영상 개요
Start by pressing the 2 clips on each side of the device to remove the tread holder head.
Once inside, pry out the size insert and the treat motor cap.
Unscrew the 2 larger Philips screws to be able to remove the base of the treat holder from the device body.
The core device can actually be accessed by the bottom; screws are hidden under the rubber pad.
The rubber pad is simply glued to the bottom, you can easily unstick it from the shell to gain access to the screws.
Under the rubber pads are 4 Philips screws to get inside.
Once inside, you'll find a board that hosts the physical controls of the device.
Remove the 2 Philips screw to remove it from its place.
Then disconnect the ribbon cable and put the board away.
Once the controls are removed, you can simply slide the core of the device out of its shell.
You'll find 3 Philips screws (2 on the left, 1 on the right) to get inside the core.
The 3 Philips screws holding the motor to the structure can be removed.
The motor won't slide out immediately – you'll also need to remove the encoder sensor. Just pull it out carefully from its socket.
While trying to slide the motor out, make sure to disconnect its cable from the main board.
The motor can then be disassembled by removing the 2 Philips screw holding its shell.
Inside the motor, just realign all the cogs together so that everything spins together.
If you want to test out the motor before reassembling everything:
Reconnect all the cables that were disconnected during disassembly
Plug the device back in
Connect to the device through the Petcube app, and try flinging a treat
The motor will instantly respond (or not) and make it easier to find what's wrong, or if the motor needs replacement.
Then to reassemble the device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Hello! This is very helpful.. mine doesn’t start up at all do you have any ideas on how to get the motor to start
