주요 콘텐츠로 건너뛰기
How to fix the power button on a Synology DS212J
필요한 것
  1. How to fix the power button on a Synology DS212J, How to fix the power button on a Synology DS212J: 1 단계, 이미지 1개 중 1개
    • Power down the Synology.
    • Since the power button no longer works you can go to the web interface [https://IP_address:5001], log in and select shutdown from the menu in the top right.
  2. How to fix the power button on a Synology DS212J: 2 단계, 이미지 1개 중 1개
    • Remove two screws from the back.
    • Make sure to put these screws where you can find them, mine are long gone!
    • Slide the side of the enclosure forward.
  3. How to fix the power button on a Synology DS212J: 4 단계, 이미지 1개 중 1개
    • As you can see the plastic of the power button has broken of.
    • I considered replacing the button but fabricobbled an easier fix.
  4. How to fix the power button on a Synology DS212J: 5 단계, 이미지 1개 중 1개
    • Remove the gray front with 3 screws for easier access.
    • Cut a bit of thin plastic to the right dimensions. (About 3 x 1 mm)
    • Superglue the thin plastic on the cross of the power button.
    • Re-assemble and if all is well you have a working power button!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Rogier Gerritse
회원 가입일: 01/17/22
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 29
전체 시간: 2,061
