주요 콘텐츠로 건너뛰기
How to fix wobbling Steering wheel on the Logitech G29 Driving Force
필요한 것
  1. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Unscrewing from the hub: 1 단계, 이미지 1/1
    • Undo the screws on the back of the steering wheel that connect it to the device hub.
  2. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Unscrewing the faceplate: 2 단계, 이미지 1/1
    • Remove the 6 bolts on the faceplate of the steering wheel.
  3. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Separating the wheel: 3 단계, 이미지 1/1
    • CAREFULLY separate the steering wheel from the base of the device.
    • Take great care not to damage the wire as you separate them.
    • Gently remove the wire connector from the steering wheel and remove the steering wheel completely.
  4. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Removing the paddle shifters: 4 단계, 이미지 1/2 How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Removing the paddle shifters: 4 단계, 이미지 2/2
    • Remove the three screws from the locations circled.
    • Remove the paddle shifter from the device.
  5. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Remove the casing: 5 단계, 이미지 1/2 How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Remove the casing: 5 단계, 이미지 2/2
    • After removing the steering wheel and paddle shifter, flip the device hub over and remove the 8 screws highlighted in red.
    • Depending on your model, you may also need to remove 2 screws on the outside of the feet.
    • After the screws are removed, flip the hub back over and remove the black casing to reveal the inside.
  6. How to fix wobbling Steering wheel on the Logitech G29 Driving Force, Tighten the screws: 6 단계, 이미지 1/1
    • Ensure that the black plastic and the metal frame of the device are as close together as possible.
    • Tighten the 4 screws highlighted in orange. This should fix the wobbling issue on your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathaniel Hyder
회원 가입일: 09/16/22
148 평판
안내서 1개 작성함
Western Carolina University, Team 1-5, Virtue Fall 2022 Western Carolina University, Team 1-5, Virtue Fall 2022 회원
WCU-VIRTUE-F22S1G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 52
30일 전: 328
전체 시간: 5,636
