주요 콘텐츠로 건너뛰기
How to flash Lenovo IdeaTab A1000L
필요한 것
  1. How to flash Lenovo IdeaTab A1000L, Welcome: 1 단계, 이미지 1/2 How to flash Lenovo IdeaTab A1000L, Welcome: 1 단계, 이미지 2/2
    • Requirements:
    • A internet conection
    • A charged A1000
    • A usb data cable
    • And most importantly a windows pc
    • Warning: don't do this if your tablet is already working or you modified the boot loader ,you can brick your tablet .
  2. How to flash Lenovo IdeaTab A1000L, Finding Firmware.: 2 단계, 이미지 1/2 How to flash Lenovo IdeaTab A1000L, Finding Firmware.: 2 단계, 이미지 2/2
  3. How to flash Lenovo IdeaTab A1000L, Unpacking the firmware: 3 단계, 이미지 1/1
    • Unzip the firmware and the flashtool in any folder only with latin characters.
  4. How to flash Lenovo IdeaTab A1000L, Flashing the firmware: 4 단계, 이미지 1/1
    • YOU CAN BRICK YOUR TABLET ON THIS STEP! I am not responsible for any bricking of a tablet.
    • open Flash_tool.exe. and select File > Open Scatter-loading file ... and select the file MT6577_Android_scatter_emmc.txt from the firmware folder
    • Check the box DA DL All With Check Sum and Press the Firmware -> Upgrade button
    • If this <-- happens check the firmware and delete checksum.ini from the firmware and try again
    • Plug in your tablet turned off
    • First wait if you get a green circle after flashing you have a successfully flashed tablet.
결론
Congratulations you have a working tablet
다른 한 분이 해당 안내서를 완성하였습니다.
SilverDimond
회원 가입일: 09/07/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 39
전체 시간: 649
