주요 콘텐츠로 건너뛰기
How to flash MNT Reform LPC firmware
필요한 것
  1. How to flash MNT Reform LPC firmware, Remove Bottom Plate Screws: 1 단계, 이미지 1개 중 1개
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. How to flash MNT Reform LPC firmware, Remove Bottom Plate: 2 단계, 이미지 1개 중 1개
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: 3 단계, 이미지 2개 중 1개 How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: 3 단계, 이미지 2개 중 2개
    • Use a spudger or your fingernail to set the DIP switch LPCP to ON.
    • The LPCP switch is located on the motherboard, between the CPU module and trackball or trackpad.
  4. How to flash MNT Reform LPC firmware, Press LPCRESET: 4 단계, 이미지 1개 중 1개
    • Use a spudger or your finger to press the LPCRST button next to the DIP switch from the previous step.
  5. How to flash MNT Reform LPC firmware, Plug in a USB cable: 5 단계, 이미지 1개 중 1개
    • Connect a Micro-USB cable into the LPC USB port.
    • On newer revisions of the Reform, the Micro-USB port has been replaced with a USB type-C port.
  6. How to flash MNT Reform LPC firmware, Flash the LPC firmware: 6 단계, 이미지 1개 중 1개
    • Plug the other end of the cable into another computer. The system controller's memory appears as a virtual flash drive on that computer.
    • Open a terminal and navigate to the reform2-lpc-fw folder you've downloaded from the Reform repository.
    • Check lsblk or dmesg -w to find out which drive the LPC shows up as, then edit flash.sh with the correct path to the virtual flash drive (e.g. /dev/sdx).
    • Double-check the path to make sure it is correct, as entering the wrong one could destroy data on your computer!
    • Execute flash.sh as root.
  7. How to flash MNT Reform LPC firmware, Unplug the USB cable: 7 단계, 이미지 1개 중 1개
    • Disconnect the USB cable from the LPC USB port.
  8. How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: 8 단계, 이미지 2개 중 1개 How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: 8 단계, 이미지 2개 중 2개
    • Use a spudger or your fingernail to set the DIP switch LPCP to OFF, which is the side labeled "1".
  9. How to flash MNT Reform LPC firmware, Press LPCRESET again: 9 단계, 이미지 1개 중 1개
    • Use a spudger or your finger to press the LPCRST button again.
결론
To reassemble your device, follow steps 1 and 2 in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Neelfyn
회원 가입일: 05/13/14
981 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 42
전체 시간: 1,362
