주요 콘텐츠로 건너뛰기
How to force restart your Fitbit Ionic
  1. How to force restart your Fitbit Ionic, Force Restart: 1 단계, 이미지 1개 중 1개
    • Press and hold all three buttons on the Ionic until you see the Fitbit logo.
    • You may notice your screen flash to black for a brief second. Continue to hold all three buttons.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Carlos Oulman
회원 가입일: 10/22/17
2,163 평판
안내서 1개를 작성함
Tech Beam Media Tech Beam Media 회원
Business
4 회원들
안내서 3개를 작성함
15가이드 댓글
More than likely your ionic will brick itself if you do a factory reset, mine did.
gregory_91 - 답글
This guide does not show how to do a factory reset but rather shows how to force the device to restart.
Carlos Oulman -
Yes I bricked mine too
Paul Keelagher -
Thank you for this. I accidentally discovered this. It took 8 hours to not get this suggestion from Fitbit support.
Natasha ten Krooden - 답글
Thanks Carlos. My main screen was black this morning. I could swipe to other screens, and found instructions about powering down using the Settings etc, but Settings just stayed on Settings for me, so I had to find some way of using the buttons to restart. I found this! It worked for me. Back to normal after restart.
coopergraham5 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 65
전체 시간: 40,633
