주요 콘텐츠로 건너뛰기
How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears
필요한 것
  1. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: 1 단계, 이미지 1/1
    • Turn the device over so that the base is on top.
  2. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 2 단계, 이미지 1/1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 3 단계, 이미지 1/2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 3 단계, 이미지 2/2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: 4 단계, 이미지 1/2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: 4 단계, 이미지 2/2
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  5. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 5 단계, 이미지 1/2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 5 단계, 이미지 2/2
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
  6. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 6 단계, 이미지 1/1
    • Unscrew the two 10 mm philips head screws.
    • Unscrew the center 14 mm philips head screw.
    • Remove the plastic piece stabilizing the gear.
  7. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: 7 단계, 이미지 1/1
    • Apply oil to the gear directly from the oil bottle or with a Q-tip.
결론
Nick Kaprielian
회원 가입일: 01/14/14
525 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 회원
CPSU-FORTE-W14S17G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 1,102
