주요 콘텐츠로 건너뛰기
How to install Soft Close Richelieu Drawer slides
필요한 것
  1. How to install Soft Close Richelieu Drawer slides, How to install Soft Close Richelieu Drawer slides: 1 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides, How to install Soft Close Richelieu Drawer slides: 1 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides, How to install Soft Close Richelieu Drawer slides: 1 단계, 이미지 3/3
    • Remove the metal glide from the drawer by pulling and pinching the lever at the same time.
  2. How to install Soft Close Richelieu Drawer slides: 2 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 2 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 2 단계, 이미지 3/3
    • Place the slides flush with the front of the cabinet, and clamp it down to screw it in place.
    • If no clamp is available, use tape or a partner to help hold it in place if possible.
    • It is always better to have the slides slightly inside the cabinet than outside of the cabinet
  3. How to install Soft Close Richelieu Drawer slides: 3 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 3 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 3 단계, 이미지 3/3
    • Insert all 8 of the 1/4" euro screws with the power drill putting 3 screws in total, from front, middle, and the back of the track.
    • If there is no power drill on hand, you can use an awl to create holes.
  4. How to install Soft Close Richelieu Drawer slides: 4 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 4 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 4 단계, 이미지 3/3
    • Install the track on the mirror side of the cabinet using the same process of step 3.
    • Repeat steps 2-3 for this.
  5. How to install Soft Close Richelieu Drawer slides: 5 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 5 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 5 단계, 이미지 3/3
    • Push the metal glides back into the track until it clicks back in place.
    • Place a cardboard box material or any material that is less than 1/8" thick at the bottom of the cabinet. The spacer will prevent the drawer from scraping the bottom side of the cabinet when we install it.
  6. How to install Soft Close Richelieu Drawer slides: 6 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 6 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 6 단계, 이미지 3/3
    • With the spacer, we have ensure our drawer will be aligned perfectly for marking the metal glides' placement.
    • All we have to do now is to bring both drawer and metal glide slightly out of the cabinet and mark the placement with pencil on both sides of the drawer.
  7. How to install Soft Close Richelieu Drawer slides: 7 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 7 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 7 단계, 이미지 3/3
    • Measure the markup distance, and draw another line with the same measurement at the back of the drawer.
    • Line up the metal glide, and clamp it in place with our marker.
  8. How to install Soft Close Richelieu Drawer slides: 8 단계, 이미지 1/2 How to install Soft Close Richelieu Drawer slides: 8 단계, 이미지 2/2
    • Insert 6 of the 1/2" screws using the power drill or screwdriver while making sure that the tip of the glide is flush with the front of the drawer.
    • Using the same step as before, screw the glides on the opposite side of the drawer.
  9. How to install Soft Close Richelieu Drawer slides: 9 단계, 이미지 1/3 How to install Soft Close Richelieu Drawer slides: 9 단계, 이미지 2/3 How to install Soft Close Richelieu Drawer slides: 9 단계, 이미지 3/3
    • Carefully place the drawer in the track, and push it all the way back until you hear a click. Once the drawer is in place, the slides should work properly and move with ease.
    • At last, the installation is finished!
결론
To reassemble your device, follow these instructions in reverse order. We hope this guide provided you with a perfect way to install soft-close drawers. Please use these for alternative brands, and comment if assistance is needed.
다른 3명이 해당 안내서를 완성하였습니다.
Felix Alimin
회원 가입일: 01/27/23
223 평판
안내서 1개 작성함
York University, Team P-1, Allen Winter 2023 York University, Team P-1, Allen Winter 2023 회원
YORK-ALLEN-W23SPG1
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Thank you! I built a table for a Dewalt 733 Planer that a friend gave to me. I used scrap material, pretty much, from my pole barn project, to complete this workshop table. I decided that a drawer would be good to hold my extra knives and correct tools for changing the blades. My table is a bit deeper than 24”, so I checked out drawer slides at Lowe’s. I was shocked to see that I could purchase the 24” soft close heavy duty slides for $6.98/pair! Regular price was almost $26! I grabbed those babies up and lit a shuck to the cash register! 😂 I hadn’t put slides into a cabinet for a couple years, so I brushed up with this very well laid out set of instructions and am now more confident that I will be able to install these well-built slides with ease! You are much appreciated! Thanks, again! Amber
Amber Orm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 48
30일 전: 175
전체 시간: 4,076
