주요 콘텐츠로 건너뛰기
How to install Windows 98 SE
    • At the first screen, choose "Boot from CD-ROM", then "Start Windows 98 Setup from CD-ROM"
    • Wait for Setup to initialize
    • When prompted, configure unallocated disk space and, if your drive is over 512MB, enable large disk support
    • Press ENTER to reboot.
    • Preform the same inputs as you did the first time and wait for Windows 98 to format the disk.
    • Once you get to the Welcome screen, press Continue.
    • Wait for Setup to initialize.
    • On the next screen, choose what you want the Windows directory to be. If you're unsure, leave it at the default C:\Windows.
    • Do not use special characters in the Windows directory path. Doing so may break some system components.
    • On the next screen, choose the components you want installed. If you want to customize per component, choose Custom.
    • On the next screen, enter your computer name, workgroup name, and a description for your computer. If you're unsure on any of these, leave them at their defaults.
    • Choose your region, click "Next", and wait for Windows 98 to reboot.
    • If you still have the CD inserted, press "Boot from Hard Disk". Otherwise, Windows 98 should boot automatically.
    • Next, enter your name and your organization's name.
    • On the next screens, accept the EULA and enter your product key.
    • Lastly, press Finish and wait for Windows 98 to complete installation.
    • This stage can often have errors. If you encounter errors or if Setup freezes, rebooting may fix it.
    • At the user login screen, enter your username and password. Since this is the first login, Windows 98 will have you confirm your password.
    • Explorer should load after this. If it doesn't, you may need to reinstall.
결승점
작성자
1다른 기여자 명과 함께
Sean-e
회원 가입일: 08/18/25
676 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 47
전체 시간: 139
